Need more help with my fuel pump PLEASE!?
Hardwareman
SoCal
Well my old (original) fuel pump went out about 2 months ago and I replaced it with a new one. I bought the PUMP ONLY, not the entire assembly!
I immediately had a problem with the new pump. As soon as I would get to a 1/4 tank or less the truck would randomly stall on me from not getting fuel. It seems to happen more while going downhill but I'm not certain.
I noticed the new pump was VERY hard to get seated properly into the base of the assembly because the old rubber line was angled and the new line was straight. I decided to remove the newly installed pump and try to correct the problem thinking that may have been the problem......WRONG!!!
Is there something else I need to check, or could this simply be a fuel filter problem getiing debri from the bottom of the tank? Thanks.
Allen
Now that I think about it, it never happens under acceleration. If that matters. I think I'm going to go down to my local AutoZone right now and drop the $10 on a new fuel filter. It has'nt been changed in ages. Thanks
Allen
The parts stores here won't warranty a new pump unless you have a reciept for a filter on the same day. A plugged filter is often the cause of a failed pump. What about the strainer? did you replace it? Is it on properly?
Yeah you're right. When they told me that I bought a new filter/screen deal for the pump when I bought it at AutoZone a couple months ago. I'm talking about the filter that's downstream inside the framerail on the drivers side.
For some reason ford put two filters on the fuel system. I have'nt changed the inline filter in over 5 years. It actually may be longer then that. I know there's well over 150,000 miles on that filter.
Could that be my problem? Thanks.
Allen
Well wish me luck here..........I just pulled out my old one and replaced it with a new one. I could'nt even blow through the old one! I could blow through the new one like regular breathing. Now all I have to do is take a quick shower to get the gas out of my mouth and test drive it. Wish me luck! Thanks Mutant Pony!
[/IMG]
Allen
Well, it's still not fixed. Just took it for a test run with the new fuel filter on and it's still dying on me when I come to a quick downhill stop at idle.
It has to either be my fuel filter (which I just replaced) or my fuel pump because when I have a 1/2 tank or more it does'nt do it. I'm pretty sure I put the pump and strainer on right. I had to make sure the strainer would'nt interfere with the float.
Any other ideas? Thanks.
Allen
