BroncDueceLV
- Nov 5, 2013
I've had my Bronco 2 for a few months now and have been trying to do most the problem diagnosis and repairs myself, however, I have very little mechanical experience. I have an 88 manual 2WD Bronco 2 with no modifications and I was wondering if anyone new where to start looking with the following problems:
Speedo and Odometer randomly stopped working, all other electronics seem fine.
Oil pressure runs a little high (close to max) especially at highway speeds. I had an oil change a few days ago and it did not help.
Truck recently (2 weeks ago) began rumbling at idle, when I first bought it this was never an issue.
Occasionally coming out of first the truck gets close to stalling, this issue seems to go away after it runs awhile.
The speakers blast a lot of fuzzy interference.
Engine Block appears moist, maybe needs to gaskets? but I do not get drips below the vehicle.
I have replaced the battery, the upper radiator hose, the oil pressure sender, the multifunction switch, and a vacuum hose going from the fuel pressure regulator to the engine. Otherwise the vehicle is completely stock as far as I know.
Any help would be greatly appreciated.
