Need help on 94 ranger either short or bad alternator or something else
Does ignition control module color matter
Your truck has DIS (not EDIS), some versions of DIS used a cam position sensor for SEFI fuel injection (yours doesn't), I'm not sure if the modules are the same or plug compatible. You would have to pull the part number off and go to a good parts website to decode like Rockauto, etc.
Update on truck still isn't fixed talked to ford asset program teacher at job he said try a new alternator not a rebuilt one so I did no luck also tried a new computer no luck and a new ignition control module and no luck so now I'm back to tracing wiring
Could bad wiring at turn signal switch be the issue or am I solving a different issue I hadn't noticed
  • Need help on 94 ranger either short or bad alternator or something else
Got turn signal patched up and it shows its charging for a bit and then goes back to no charge its trying to run longer but is popping while running
Alright checked voltage to wires on alternator circuit since new alternator was put on. The yellow white wire is at 12.5 volts with key off as it and the light green red wire only has 3.48 volts with key on after its connected to alternator unhooked from alternator its at 12.5 volts
I went to alternator rebuild shop had them test new alternator it tested good and they made old alternator a one wire alternator to bypass alternator wiring circuit. Truck still won't run. While truck is attempting to run the one wire alternator is putting out correct voltage even tried a different battery again. Hooked up my battery charger and it ran but it only goes up to 8 amps of charge on battery charger. So truck will run on low amp charge or on battery power but not on alternator charge
What does the large output wire read with the meter with the engine off? It should read battery voltage. There is a fusible link in this wire (fusible link C)
I've redone that wire when I went back over wiring i could shake it and reading would jump around. But now it reads 12.96 no matter how hard I shake the wire
Found the truck is backfeeding. on battery voltage with alternator unhooked the Grey signal wire on cranksensor reads between .5 to 1 volt ac but when alternator is hooked up that Grey wire goes to 4 volts ac. I did the testing based off of how Google said to test it
Ac voltage yes its how Google said to test it that Grey wire from crank sensor.
I guess that makes sense in a way. It really needs an oscilloscope to be accurate. The way I understand it, the shape (and timing) of the waveform is the important part.
Not really AC. It is pulsing DC. The voltage rises and falls, but does not go negative like AC. Reading it with a multimeter on the AC scale is a very crude way of getting some kind of measurement.
Crude is right. Like testing for spark by holding the plug wire... LOL
Just read the entire thread and I'm curious about the backfiring. The crank sensor wiring should be shielded right? Maybe it's getting shorted or getting interference when the alternator or jumper cables from the other vehicle is hooked up?
I hope you figure it out
