GOODOLEBOY84
- Aug 28, 2007
- Age
- 41
- Automatic
the timing is fine, its a stock motor other than a 4 brl carb, it was running fine, then after it sat it started doing this, its not pinging, it wont hardly run now, its an electrical problem, im just not sure what at them moment, when you test the voltage at the coil you get 7 volts, with the engine running or not, it has a resistor wire built into the harness
