NEED HELP 2wd to 4wd conversion for 07
well its a good thing i saved it all to a word document when you first posted it haha. i saved your posts with the ABS light problems too...but it ends when you were going to test if you got the 4lo light to come on...getting the manual t-case to work on the 04+ cluster/computer almost sounds harder then the swap its self
oh yes, what did you do for the trannie? keep your stock 4x2 and change the tailshaft housing for a 4x4? I have never seen a 3.0 4x4, where did you find it?
i have a 98 frame and axles all you would need is a transfer case and a 4x4 trans. $300 for all
I had a 99 4wd with a 3.0 5sp. It was a little underpowered with 3:73's and 31x10.50's
