The_Dealer
Ok guys, I'm in mid 5.0 swap, got the motor back from the man. Gonna run an edelbrock avs carb, had one in the past and it worked good. Gonna go efi in the future. Anyways I'm going to run an elect fuel pump, and need help with wiring. I want it to come on with the key like factory electrical pumps. The ignition is duraspark. What wire do I tap into for it to come on with the key like factory? Rig is an 85. Also the factory harness was stripped when I did the d-spark swap back when I ran the 2.8. So I'm wondering how do I wire in the electric choke for the carb? Is there a special wiring kit I need? If not what wires do I need to tap? I'm so close to getting everything in, and wiring isn't my strongpoint. Thanks guys!
