Wanted Need a wheel center cap
modelafish
Nampa, Idaho
I need a wheel center cap like the one pictured. I picked up these wheels at a local pick-and-pull in the Ranger section. Looks like they were on 2001-2007 models. Only found one center cap. UPDATE: Found one. Thanks
That appears to be s center cap from an Alcoa wheel that was a factory offering on a FX4 Ranger.
Nice find on the wheels... and good luck in your search for center caps.
I've seen some on ebay in the past.
Those originals are too expensive. I say make your own custom center caps.
I'm all for DIY, but my brain's not the creative kind. I don't really need the cap to come out far like the other one. It's on an 8" rear axle. I spent a couple hours going thru the Ford section at a couple local pick and pull places looking at what other models had, but nothing in the 3" range. As far as making something, all I envision is something made out of aluminum or even wood on a lathe. (which I don't have). I really don't like the looks of those roughly 6" caps that snap over all five lugs. This is how the one I do have looks:
The center caps, if you will, I made for the Magnum 500's on my '75 Ranchero. Some at car shows ask if these are holding the wheels on.
Just pmed you. I believe I have one
Aren't these same center caps on Crown Vics with alloy wheels?
