- Aug 16, 2014
- State - Country
- NV - USA
- Vehicle
- Ford Bronco II
- Drive
- 4WD
- 4.0L
Ok here we go. Got a 87 Bronco ll with a transplant 93 Explorer 4.0 manual. Was completed 6-7 years ago after alot of hair pulling ,calling wife to come rescue me, and a few calls to AAA. All together have a little over 100k on the setup. It's ran reliably for all these years until last Thursday when it died along the road. Acted like no fuel so called the wife to come gather me up, again, so I could grab the Chevy and tow bar to get her home. Got home hooked up fuel tester 0 PSI. Does the crank no start thing. The rear tank pump runs but the frame rail one doesn't. Did some tests that came to conclusion the frame pump was no good. Went to get a new pump and was going to install it today but thought another test was needed making sure there's power at pump connection. Low and behold no 12v power but got 6.8 volts on the ground side. I'm no way any good at electrical diag so I come here looking for some suggestions and maybe a process to check things to help get my Bronco ll back up and running. Here's what I can remember doing so far. Pulled the fuel pump relay checked for power have it at relay, went to inertia switch no 12v with key on. I watched a video with a guy working on a 87 Ranger with a similar issue going thru step by step and I got to the inertia switch part that failed so going further didn't make sense. Thanks in advance for your thoughts, suggestions, and encouragement.
