- Feb 19, 2008
- Age
- 65
- Camby, IN
- 4.0L
- Manual
Ok, got the body lift in and the HID working right....Ran into a slight problem thought....It is starting to over heat now....Any way to fix this? The brackets for the fan shroud were installed
Is there a gap at the top of the shroud after you relocated it?
May need to block that off to keep the air moving through the radiator, and not cycling back in from the engine compartment.
The thing up top is a remote control spotlight
