Nater's 1994 Mazda B2300 project
looking good man
u need to raise the bull bar a bit more tho
my truck has the 3.73 gears btw
I was thinking the same thing. but that will require me to make some new holes in the brackets. The bar and bracketry are for a 2000 + Ranger. I will probably raise it when we do the body lift.
yeah it would look 10x better
hope to see the body lift soon
The BL should be in this week along with the new bushings...(Summit has never let me down yet) The weekend following (29th) is when we are planning on doing it.
i like it. makes me not too worried about being stationed in europe. i don't wanna be stuck in a midget car. is that US legal or naw?
Yes....these are the new USAEUR plates....they want us not to stick out as much....but come on.. Our cars stick out like a sore thumb! LOL! You going to Ramstein?
WAHOOOO!!!!!!:yahoo::yahoo: PA Body lift has arrived! Be another week or so till I can install it.
Don't do serious off roading here...just some dirt trails and everything...
Wow...you will be a bit of a drive from me...I am about 4-5 hours southeast of there..(about 45-60 minutes from the Czech border)
After a lot of cussing and a bloody knuckle, got my Bi-Xenon HIDs installed...Went with the 6000k. For those of you that run into the problem like me where Hi beams don't work and the high beam indicator is still lit even though the high beams are not on, Check this out...
First double check thru a wiring diagram and see which wires are ground and which are hi and lows. Here comes the fun part....playing musical wires on the HID plug. I finally found a wiring diagram for the HID kit and found out that the wires going to the harness were all mixed up... So after moving the wires to the correct points, all works great now!
Body lift will hopefully go on this weekend....then more pics!
All the kits I get, 4 so far, are all plug and play.
Ok, got the body lift in and the HID working right....Ran into a slight problem thought....It is starting to over heat now....Any way to fix this? The brackets for the fan shroud were installed
