After a lot of cussing and a bloody knuckle, got my Bi-Xenon HIDs installed...Went with the 6000k. For those of you that run into the problem like me where Hi beams don't work and the high beam indicator is still lit even though the high beams are not on, Check this out...
First double check thru a wiring diagram and see which wires are ground and which are hi and lows. Here comes the fun part....playing musical wires on the HID plug. I finally found a wiring diagram for the HID kit and found out that the wires going to the harness were all mixed up... So after moving the wires to the correct points, all works great now!
Body lift will hopefully go on this weekend....then more pics!
