4.0L OHV Mystery Knock after Rebuild
Featured Build Threads
broncc
5+ Year Member
Ham Radio Operator
N/A
MA - USA
Other
1979 Mercury Capri RS, 1979 Ford Thunderbird
Vehicle
Ford Bronco II
Drive
5"
Giving my truck more money than it deserves.
Hello all...
Long story short I had to put a reman crankshaft in my 4.0. When I started it back up it was knocking! I have it back apart now and I'm properly stumped. The rods all measure perfect 0.0015 clearance with my 10 under bearings. It sounded like it was coming from the bottom when it happened. I'm going to pull the first three main caps tomorrow.
Does anyone have advice or experience with what it could be? I'm running out of ideas and I'm not sure it was a collapsed lifter. I don't recall it sounding like one and I'd rather not pull the top end apart to see if lifters that have been sitting for a long time are pumped up.
Without hearing it...
Plasti-gage it.
Did it have good oil pressure?
Flywheel got torqued?
No beat up marks on the rod bearings?
Bearings came out looking brand new. Plastigagued to 0.0015. All flywheel bolts seemed tight. I recall oil pressure being fine.
Even gave it a little rev back before parking it out of frustration.
End play good?
Did you do cam and lifters when ya did the crank?
Crank endplay is within spec. Rod bearing end play was not mesured but seemed fine. Camshaft and lifters are original with the motor and were not giving trouble before this.
I'm going to see if I can verify the timing chain tensioner that I replaced a while ago survived the rebuild. I'm pretty sure I got the timing right because it ran nice while knocking. Point the two dots at each other like a small block.
How long was it running? It's possible a lifter is taking its time to fill back up. Any marks on the windage tray where a rod would be? Maybe there were spacers on the main cap studs that got misplaced?
The crazy part is that I ran it for a minute in a hail mary hope that it was just a lifter that needed some time. The bearings aren't hammered at all so maybe there is some truth to it. I have been super busy and haven't had time to get back to it. I did poke a borescope into the plug holes and nothing looked bad.
Sound anything like this?
That was the first start after re-gasketing and new pushrods and rocker arms on my OHV. I thought for sure it wouldn't last 5 minutes. The noise carried on for about 15 minutes then got totally silent.
You know it kind of does....
The rod and main bearings all measured within spec. Timing chain seems ok? I took the valve covers off and most of them are soft. The motor sat for a while before I pulled so it won't provide useful information until I pump them up. Does anyone know what socket fits on the oil pump driveshaft? It's not E10...
I dripped a little bit of MMO on top of each lifter maybe it will help free up gunk causing a leak on the lifter check valve.
Put the engine in just enough to attach a starer and spin it over. Everything sounds fine to me. Oil is coming out of the rockers but the lifters have not pumped up. I guess I need time or acetone in the crank to see if I can recover the lifters.
Hate to try this with new parts but I had a 4.0 that had awful lifter noise. I dumped a quart of diesel fuel into the oil and just let it idle for about 30 minutes. 90% of the lifter noise was gone so I just changed the oil and ran it. I sold the truck real cheap as a beater rig so I don't know if that fix stuck long term but it helped a lot.
I had another one that sat for a long time and it sounded like it was going to come apart when I first started it. Sounded like a knock and lifter noise...BAD noises... figured I had nothing to lose so I let it sit and idle and it just cleared up and was totally quiet after maybe 2 minutes. It never made any abnormal noise after that either. No glitter in the oil, no chunks, just a good running engine. That was very strange.
Maybe spinning it with 0 compression (plugs out) would help?
I've been pretty busy lately but the car is ready to run. It just needs the battery charged and coolant added. I did spin it with no plugs in last week.
You wont believe it but there was no knock on start. I drove it to the gas station no problem other than a ruined battery. What a waste of time.
I'm going to attribute that to squishing the lifter a lot in the presence of solvents.
Featured Ranger Based Vehicle
