My New House & Workshop
I ordered my wire because nobody had it in stock.
I ordered:
  • 300-feet of 1 AWG Black Stranded AL USE-2 Cable. (This will be for (3) 100' sections. I couldn't order it as (3) separate cables unless I made (3) separate orders, so I'll have to cut it.)
  • 100-feet of 8 AWG Green Stranded CU SIMpull THHN Wire (the copper was only $0.10 more a foot than the aluminum)
The wire came to $361 with tax which is about 1/4th of what it was going to cost if I went with all copper.
I also went and bought a 100 AMP 20-space breaker panel. I could have got by with a 12-space panel, but they don't have a main shutoff. The breaker panel with tax was around $114.
Not only did the old subpanel have some sketchy wiring, but it was also hooked to the meter with no main shutoff. So, you couldn't get in there and work on it without it being live. That must have been fun.
Don't forget to buy small rolls of white and red tape. The white will be important to not get the neutral mixed up with the other wires when you cut them. The red not so much, you can get the two hot wires mixed up and it won't matter. But since we are following code, they state they must be marked, so your hot wires will be black and red. You have the green already covered.
You didn't mention anything about black phase marking tape. ;missingteeth;
I got a small pack of different color electrical tape that included white, green, and red. I ended up ordering green wire so I don't need that. Obviously white for neutral. They say it doesn't matter which hit goes where, but I wanted to mark one with red so I at least know which wire is which.
I still need a ground rod to drive into the ground and some copper wire to go to it.
Unless someone corrects me, I do not think you need to drive a ground rod, since you will be using the grounding system from the house with the ground wire you bought. But I guess it wouldn't hurt if you wanted to add it in.
Here's what the grounding bar looks like that you will have to buy and add to your new panel.
Since it is a separate building, he needs to have a ground rod at that building.
I think I'm going to go ahead and bury a shielded ethernet cable in another conduit and hook it to the Wi-Fi in the house to have Wi-Fi in that building. I just need be careful to space them apart to avoid interference.
My internet comes into a small box mounted to the wall that has a cable that runs to a Nokia WiFi Beacon 6. Doing a little searching, it looks like I can hook an ethernet cable to the LAN 1 port on the Nokia and connect it to another Beacon 6 on the other end. Not sure what it would cost for me to get one from my internet provider, but I can find the Beacon 6's on Ebay for $60.
FWIW, I had metal roofs on 4 stalls of my garage and my house. I got rid of it because, even though I torqued the roof screws down, the rubber gasket between the roof and the screw deteriorated due to pressure and the sun. I didn't like the possibility of a roof leak, so it's now gone.
I've read that there is a new style roof that the screws do not show. I'd personally suggest looking into it, for the reasons stated above. Just my $0.02
You don't need to use another router just for wifi, You can just use an access point. If all you need is basic internet to browse the web and maybe watch a YouTube video I'd just use one of these set up in access point mode. The app make set up simple. Plug it in the wall and then plug in your ethernet cable. If you set the SSID and password the same as your wifi in the house your devices should immediately pick it up.
Forgot the link: https://www.amazon.com/Wifi-Extender-Booster-Wireless-Repeater/dp/B08RHD97QY/?tag=959media-20
I don't think that would work that well. The Wi-Fi is inside my house, and I need it inside a concrete block building 100+ feet away.
That type is called "standing seam metal roof", or "snap-lock" as a trade name. No exposed fasteners.
That's what I redid my roof with, from asphalt shingles, and it's about the best decision I've ever made on the house. Definitely worth it.
You'll get better, more reliable service with the cable.
That's what the ethernet cable is for. You want to set it up as an access point not a repeater. You can buy a dedicated access point but they can be a bit more expensive and some are a pain to set up. We've got several of these at work I've repurposed as emergency access points when a POE switch goes out or something similar happens. They easily cover a cabin the size of your shop and usually are supporting 2-4 cell phones and at least 1 TV streaming with no issues at all.
willindsay and Jim are talking about the same thing. Just use the second router as an access point instead of double routing.
Wouldn't have to use the same thing in the shed, but If your happy with it inside and it's cheap enough, why not?
