@Jim Oaks
Poor man’s strain gauge.
Per our brief chat, cut a little piece of flat plastic about 1-1/2 inches high and maybe four or 6 inches long
Use something like E6000 to glue it to the wall across the crack, but only glue it on one side of the crack. It’s very important that it lays flat. For your case, I would just use a 2 x 4 and lean it against it while the glue sets.
After the Glue sets up, so there is no motion at all on the piece of plastic, use a straight edge and make a couple of vertical lines that start on the plastic and run onto the wall. Do two vertical, and two horizontal.
Do one of these about 3/4 of the way up the wall, and do a second one about 8 inches off the ground.
I would take pictures because your phone camera will see it close up much better than you can with your eyes. (if your eyes are anything like my eyes).
You need several pictures over time, but it’s not based on a standard time interval.  The different pictures would be based on changes in temperature, rainfall, drought, sunlight, etc.
I believe the back of your place just wasn’t built as well as the front half of your place, and on that Texas soil, it is moving up and down a little bit.  If you take a picture when it’s dry, a picture after a big rainfall (like 12 or 14 hours after allowing for the moisture to penetrate the ground), when the sun is on the wall, when the wall is cool at night, etc., etc. Anything that would cause expansion or contraction of the wall, the building, but mostly the soil
There are a few possibilities. The most likely is that the ground is moving, so the two sides of the crack are pivoting, with the pivot point being where the slabs meet.
The other possibility is that the entire slab is moving either up and down, or back-and-forth, maybe even at a horizontal angle, or a complex twist. That’s the purpose of the two gauges. If the upper one shows any kind of motion and the bottom one doesn’t, it’s pivoting.  If both of them show motion, it could be the whole slab moving around, up-and-down, or back-and-forth.
If there’s any kind of a crack or seam that’s not tight on the far side of the building, put a couple gauges there as well.
Over a month or six weeks, with a couple rainfalls and a couple of dry spells and a few changes in temperature, the building will speak to you through the strain gauges
It’s very critical the plastic lays flat, and equally critical that your pencil lines are precise from the plastic to the wall. If it’s a sloppy line, it’s not going to tell you anything.
If your memory is like mine, put a number on each of the strain gauges, and take a picture of all four at the same time.  I’m pretty sure you understand the concept, but if you get a bunch of pictures overtime, and you make notes on when it rained, and when it was dry, sunny and such, and you want to send them to me, I’m used to reading them.  If it’s pivoting, it’s easy to see. But if the four gauges are moving in four different directions, it becomes a nerd problem.
Final thought. If there is a crack across the floor anywhere near that crack in the wall, you may want to put two or three of these strain gauges down on the floor and put them in images too.
For the numbering system, front wall one, front wall two, would be FW1 FW2, slab 1 S1, etc.
As always, my two cents, hope it helps
