Here ya go, obviously I did this very quickly. The strength is in the triangle, whether it’s one or a combination of several. Right angles are very week if not part of a triangle. The shorter the short side of the triangle, the weaker it is.
@Jim Oaks examples 2&3 will fail, dangerous. Examples 4,5,6 &
@1990RangerinSK second/horizontals example are weak, but they’re covered in my second example, you could use that.
Snowy’s example one will also fail, but it was the inspiration. It is not a scissor truss. In a scissor truss the lower angled members have to tie in to the higher angle member on the opposite side directly. The way Snowy has it drawn, under a heavy load, the two lower angles would push up into the horizontal and snap it in half just before the whole roof came down. But it was a valiant effort and I honor him, except for the whole roof falls down part.
First, DO NOT remove the existing crossmember until the new pieces are glued and screwed and glue is set (typ 3 days). Weatherproof liquid nails, a lot, 2-1/2” torx deck screws.
You can modify the existing pieces into a scissor truss. Before you proceed, I’d need to know the size of the 2xs, and lengths. If it’s too shallow, it will fail, but I know several ways to strengthen it. So this is a start.
Important: if the free space between the ridge board and new lower angle boarded is less than approx 3ft, we have to rethink it. If it’s 4-5 better. So, pull a couple strings where these scissors will be and measure up from the floor to see if you get the clearance you want at the 4 corners.
See “blueprints”
While I put in the option of just moving the crossmember higher, I cannot impress upon you enough that the entire weight of the roof and anything on top of it will be at a point load where that new crossmember ends. I fear it will snap a 2 x 6 or 2 x 8 like a toothpick with 6 inches of snow on the roof. And, without strengthening (scabs) the walls will still be pushed outward. If you choose that option, you need to scab another 2x whatever the same size on at least one side of the free part of the angled 2x, extending 24 to 36 inches upward past that point on the lower side, it has to be cut to exactly match the existing so it ends up resting on top of the wall plate. A variance of that is to use some half-inch plywood (plywood, not waferboard, not a 1x). While that might be stronger, but it is much more difficult to get it right.
On the lengthwise double 2x4 straps, us walk studs, and I can show you how to glue it in a slight arch, so load is transferred to the neighboring indisturbed rafters
If you hear cracking, don’t stand underneath it looking up with a flashlight looking for the problem.
If you pick one, I can provide much better details
Good lock!
