- May 15, 2020
- Age
- 70
- Atlanta
- State - Country
- GA - USA
- Other
- Manufacturers factory tour, maybe big dealership tour
- Vehicle
- Ford Ranger
- 4.0 V6
- Total Lift
- 97 stock, 3” on 87
- Total Drop
- N/A
- Tire Size
- 235/75-15
- My credo
- Never put off ‘til tomorrow what you can put off indefinitely
Oddly enough, these two outlets are the only ones on that breaker. This is where the microwave should be plugged in. Who wants their microwave next to the sink?
I like to tackle one problem at a time, divide and conquer, but a comprehensive approach to all problems, properly balanced, is always the best solution, even if hard to visualize.
Trust me again. Run a copper wire through the sewer line to the alley from the kitchen, but make it long enough to reach the house crapper. Splice the line into the shop crapper. Extend that line over the addition roof if you raise the roof or frame out a new section. If you go metal, you only have to attach it to the metal frame. Then, place one foot in the commode (either), and with one hand, hold a tin coffee can (or soup can) inside the microwave, press the start button with your member touching the stainless sink or faucet (this part just for a thrill). Then, with the other hand, use a 102” stainless CB antenna whip to reset the GFI breaker (either one). This will set off the methane in the dip under the shop addition.
As your ass passes the moon, look back, you’ll have a perfect vantage point to visualize the shop possibilities.
Welcome to the joys of (old) home ownership!
My 2 cents, hope it helps. New drawings to follow...
