My motor swap
I converted my 77 Comet to manual steering leaving the P/S box in place. It's not hard to steer at all.
so did you just loop the 2 lines?
No, I replaced the drag link and pitman arm with new manual steering pieces. Removed all traces of the power setup. Needed the room in the 77 Comet's engine bay.
i thought all i needed was to swap my power steering gear box to a manual gear box?
You do on a Ranger. My Comet had a retarded power-ram drag link that provided the extra force. The whole system was leak prone. Like the P/S pump on my Ranger is today. Sum-bitch has always leaked from day one it seems like. I just keep adding fluid.
HAHAHH! well i tell you what, i can bring you my power steering pump, (its perfectly fine, and only 32K on it) you can have it if you can help me find a manual gearbox :)
oh and can i just tap my water neck like the other guy to run my thermostatic switch? and also i can then run my temp sensor to the gauge cluster gauge i guess. i guess i wont bother with the 2" temp gauge that come in that 3 gauge kit
If your not running AC or Heater then where your heater hoses come off the waterpump, loop it back up to the output/input on the top of the intake. Follow me? Thats how I set mine up to run no heater. The output on top of the intake has a Tee in it that I put my sending unit into and then looped the hose back to the waterpump
I mounted the Ranger's original temp sender in the T-Stat housing, the pilot hole in the housing wasn't large enough to mount anything larger in size. The Ranger's sender was 1/4NPT, the sender for the manual gauge was 3/8 or 1/2NPT. The switch for the electric fans was 3/8NPT, it's mounted in the extra coolant port in my intake. Some intakes have three coolant ports, some only two.
well i am currently struggling to figure out what all crap i need to run a belt on this thing. i guess im going to stay v belt because thats what its balanced for, and i dont feel like changing all that out to run explo/stang brackets, itd be nice, but i wanna drive it to bad right now :(
Do what B347 did over on the RPS site. I tried to warn you about this when you started.
Just get a serp belt setup off of a Bronco or F150. I use a modified setup from a Bronc and it works well. Just make sure the pulleys line up squarely when you add your idler. I tore up a few belts before I finally got it right. Here's a pic:
my ranger is currently manual steering, ive got a pump and bracket with plans of making mine power... manual box will be comming off... may be available...
well im going with the 94-95 mustang gt stuff. i have an alt bracket in the mail. now all i need is to buy an earlier timing cover and water pump to match. i also have to find a ps bracket. i now know everything i need except for the harmonic balancer
baddad - you said an aftermarket 94-95 balancer? i know its has to be 28oz and 4 bolt. because it lines up with the pullies for the 94-5 brackets.
now ive been looking but i have only found the stock balancers for the 94-5 gts. like this one
http://cgi.ebay.com/ebaymotors/1995...TruckQ5fPartsQ5fAccessoriesQQsalenotsupported
or this one
now what is the difference?
im going to the parts store and buying a 95 timing cover and waterpump. the pulleys i can get from ebay no prob. ill get a ps pump, would my ranger ps pump fit the gt bracket?
i finally figured it all out, i know i aggrivated EVERYONE with my problems on this thing. (on rps especially, and baddad you still helped no matter what, thank you)
