- Jul 7, 2009
- Loganville GA
checked Monday for vac leaks and found none. There is no fuel leaks.. I pulled the tank a month or two ago and double checked everything... The filler neck is new and tightly seated... It holds fuel pressure after the engine is off... FPR is new and functioning... A buddy that is a pretty good mechanic seems to think it may be the MAF.. It isn't new but I cleaned it with the proper stuff. I am going to run it completly out of gas with a gas can in the bed just to see how far I can go... I checked the header tube temp Monday and they all seemed to be the same temp cept the front was a little cooler..
its like 1.31/L here
