My idea of a Shelby Ranger if there would have been one.
do you think this could be done with a 2.9 intake too?
[/IMG]:icon_hornsup:
I have an Idea for the spare tire, get one of the little cable winches from an Explorer, you would have to put a small hole behind the lic plate for the jack handle, you then can just cable the tire up and down.
Robert
4th gen Rangers also used the winch, but I think your truck is so low you may only be able to slide a donut spare underneath it:icon_twisted:
I got a winch off a S10. oh and check this out the pipe for the winch handle falls in the center of the hitch so lift tag and there it is. doesn't interfere with the receiver either. I got it semi built today but the spare I have is too big to fit. I have 23 inches to play with between the DIFF and hitch.. Going to go friday to pull a part and look for Donut from Mustang GT... I hope it will fit under her... if I get a flat on the back and have to go with a smaller tire on one side it won't mess up the Spider gears will it?
It shouldn't, the parts Ranger at work has a donut and it is an FX4 with the Torsen. Spider gears are designed to spin both sides at different speeds when going around corners so that is no different.
I will try for next weekend... Was going to today but ran out of time with another project I have going... We are working on the sand rail pretty hard now..
OH, OH, OH, pictures, pictures, take lots of pictures....:yahoo: PICTURES:yahoo:
Robert
Finally bought a head unit for the ole girl... Now I have an issue with right rear speaker wiring... It doesn't want to work for some reason?? I am just going to run a complete new wire on the one side....
Got the radio installed and wired for an amp... I got a JVC that is I Pod compatible and allows to make the color scheme the same as the gauges!!!
sweet post pics of the deck man
I have a JVC one like that in the 98, awesome deck. I'm going to miss it.
