- Sep 24, 2009
- Walls, MS
- Automatic
oh document everything you do, it's easy for you to look back and see what you have done-- and it helps others out...
anyways, this is what i've come up with (info wise):
long arms and brackets- either make them or get rusty's high clearance, brackets are $21 each from ballistic fab (or make these also)
track bar and bracket- idk yet, James duff has a prototype I might try to get one for the bracket. on the bar is make it or buy an adj EB bar (others have said it works)
steering/brakes
WJ knuckles(for crossover steering)
WJ calipers and pads
Explorer sport trac rotors (for 5x4.5)
custom arms and TRE's
w/ the stock b2 arm
Coils
looking for something about 280 ppi XJ lift coils (don't know on lenght yet)
Shocks
bilstein or some GOOD ones.. no really stiff shocks on this one!
need to know lengths before i can order these
Driveshaft
don't know yet...
Trans Crossmember
gonna make a high clearance one
should i make the long arms mount to the crossmember or no?
Gears
4.56's or 4.88's on the d30 (regear the 8.8 once i can afford tires--till then i won't have 4x4)
master install kit to make sure all the d30 is good
diff cover of some sort and lube locker (love these things)
and i'm not doing a d30 locker at the time of the swap-- wheel without one and see what happens...
Can anyone add info to this???
steering/brakes
w/ the stock b2 arm
Coils
Shocks
Driveshaft
don't know yet...
Trans Crossmember
Gears
