- Aug 6, 2007
- Age
- 39
- Caledonia, Ontario
- Automatic
got the lift leaf springs in today.
kind of a pain in the ass. All of the bushing sleeves were seized. I had to grind and cut the springs at the ends, then grind the bolts with a thin grinder wheel between the spring bushing and the spring mount in the front. Then in the rear of the spring i cut the shackle in half on the outside and air cheseled the inside that was rotten and about to break. After that i did the same thin grinder wheel on the shackle bushing bolt on the inside of the mount.
After everything said and done didn't take too long, but i got dirty as all hell! Im not a huge fan of where the rear axle is positioned. I would like it about 3/4" to 1" toward the rear. I will probably put in a lift block that will have offset holes to make up for the spring location.
I still have to modify the explorer rear axle to go under the ranger. I will try and work on that on sunday. Then i need to decide how im going to adapt to the f-150 bolt pattern in the rear. I can use adapters, or i can modify the f-150 axle shafts to fit the explorer axle and put the backing plate and brakes from the f-150 axle on the explorer axle. I like the idea of the 150 shaft modified. We'll see how things go.
