Must have spare parts list?
BroncLander
BC Canada
So when it comes to the Bronco II and Ranger, there's got to be a top 5 list on everyone's mind for spare parts to carry with you. I like to carry tools, and I like to carry spare parts for the inevitable situation where it's fix it or walk out.
So without much Ford experience at all, here's my uneducated list-
-Starter Solenoid
-Fan Belts
-Rad Hoses, Clamps
-Ball Joints/Tie Rod Ends
-Fuel Filter
My hope is that after reading some experienced comments, my list changes.
I'd think you could keep the tie rods and such in better shape than that. I haven't needed one in the 17 years I've been driving it. However I have been carrying a starter in my toolbox for a dozen years or so, but it was also 12 days before I got one delivered, so that's about a year for a day without it. It will still stay in there tho. I have a truck tool box so it doesn't make a big difference
I'm more tools needed anyway, so I can't help much with parts, I guess it always seems to be something you don't have anyway
I broke down once in Louisiana with a couple hitch hikers along for the ride, I didn't have tools or parts either.
One guy took off into town and came back with a 40 piece socket set. I started looking around and found the rotor wasn't turning. It turned out to be a tiny steel pin that held it in place, he went back to the wrecking yard and came back with one
That was outside a town named Bunkey. Seems a plantation owner had a son who couldn't speak clearly, and had a pet monkey, who he called Bunkey ;)
Anyway, tools are as important as parts
Ignition module (and tool)
Coil
Belts
U joint(s) (and tools to change mainly when towing distance)
Spare tire/jack.
Basically cheap parts that can ruin an entire trip when they fail with no real warning.
The Ujoints are for my own piece of mind...usually just when im dragging 7 or 8k with my F250 for 50+ mi. Ive had numerous U joints let loose without warning....paranoia i guess
-Starter Solenoid
-Fan Belts
-Rad Hoses, Clamps
-Fuel Filter
What is the scenario behind the spare parts list? Every day driving? Off road? There is a difference. Also what kind of off road and how far away from civilization are you getting?
The rougher you’re getting on your vehicle and how far away you are from someone coming to help makes the list bigger.
my ranger doesn't go offroad so i don't have a list like that. i used to always carry tools and fluids in vehicles but i have not needed anything like that since i don't drive a jeep anymore.
of all the 100s of thousands of miles i have put in a ranger based vehicle, i have never had one break down on a road trip, or even driving around.
I’ve found that carrying a bunch of spare parts just seems to take up space in the vehicle and usually doesn’t help anyway. Like when I blew a U-joint in the F-150 down in Pittsburgh. There was no fix there, just pull the driveshaft and lock the hubs. There may or may not have been a U-joint in the toolbox, but I had to straighten the ears and stuff, and I’m not trying to do that in the city near rush hour, I wanted out of there fast. Tools to move the driveshaft to the bed were far more important.
Between a decent mechanics tool set (the like 170-210 piece sets that you can find for $100-200) and a toolbox that I’ve thrown a collection of commonly used things in over the years, there’s an awful lot of problems I can overcome and there’s been a few times I haven’t had any of that and been quite sorry for it.
Now, that said, I have a shed that’s supposed to be for warehousing spare vehicle parts… that has saved my bacon a few times. It needs re-organized and re-stocked, but it’s everything I could get my hands on. There’s an engine that needs rebuilt, a good trans, pile of brake/steering/axle stuff, random parts…
Coil
Belts
Spare tire/jack.
Ignition module and coil. Good ones. I do have a new U joint under the seat.
It's true that the type of driving has a big impact on expected parts wear. I like the starter idea. For what it's worth it wouldn't be a bad thing to have on hand. I have a tote that I use for all my tools and stuff, and there's definitely room for a starter. I think I'll just bolt the new solenoid to the fender so if it goes I only need to swap the wires over
With a manual transmission, a starter is a non-issue. I once drove for over a month with a bad starter. Just have to plan where you park a little so you can get it rolling. Ignition module is definitely a potential problem, I’ve had them go, but usually it just affects performance rather than a all out death at first, but could go either way. Doing the mod to relocate it to the fender can help prolong its life.
Definitely what you’re doing can play a part. My F-150 likes to break things, usually U-joints. It’s my work truck and a 300-6 linked to a ZF5 with a stage 2 clutch is a good way to put enough torque into the system that with the grip from a locker and good tires, it’s always looking for the weakest link. When it detonates a U-joint though, I often have to repair or replace something and that means things like torch, welder and driveline shop usually come into play so it’s not really a valid roadside fix in my eyes. Now if we are talking back when I broke the front axle shaft in my Choptop, it would have been nice to have a spare shaft on hand to slide in. As luck would have it though, had I actually had a spare with me, knowing what I do now (for some reason, potentially the lift brackets, the axle beams are apparently too close together), I would have either broken the spare shaft or broken something else (my cross pin has a definite ding).
So I usually don’t carry much in the way of parts, but I’m also not doing a lot of lengthy trips either. I like to analyze failures especially now and see if there’s a way to reduce or eliminate future breakage. Or if I want to accept a certain amount of breakage (like my F-150, if I upgrade the axle and joints to stop the breaking, is it going to say, eat my rear differential? A driveshaft is easier and cheaper to fix…). I do like to stock some of the more common items like brake parts at home though, so then I just have to rig to get home. Space is a premium on some of my trucks so the least amount I can carry and have a reasonable expectation of getting back home to where everything is, the better. That means tools and random bits like bailing wire, duct tape, pins, clips, fuses, bulbs, bolt and screw assortment, ratchet straps, etc are far more useful than hard parts that I may not need to get home or be able to do on the road side. If it’s really that bad that I can’t rig a way home, it’s likely all the way bad and that means the tow dolly gets fetched from home anymore.
I like to carry a lot of tools and some bits and pieces, , zip ties, hose clamps, small bits that’ll let you cobble together something. Jacks and straps and such.
If I was thrashing something off-road I would consider more parts.
Fuel pump would be a good one. When they stop working they just stop, and it’s something you could actually change on the side of the road without anything special.
Spare tire’s probably the one I use the most.
Yeah a fuel pump. Good one. I think mine is mechanical. I haven't actually looked yet. 84 was still before many tank mounted pumps were a thing.
I'm still thinking my fuel pump will best be repaired with the bed out the way
It's too flat here to push a vehicle, unless you had another vehicle
It is, but it’s fairly easy to remove the bed if you have the right tools handy. Once the bolts are off you can pick it up with one hand and jamb a board under it to work on it.
Wow. I have a screw driver, a set of needle nose pliers, and side cutters in a box behind the seat- the same box I had in my Mustang when I was drag racing. Ford spare parts I have a used Duraspak module under the seat.
I suppose it's never been changed. I have a frame built to swap the motors so I'll likely follow up with pulling the bed and giving it all a once over. Think I'm looking at the next few weeks to get that motor swapped if the heat won't get much worse
