James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
- Aug 31, 2021
- Roanoke VA
- 1997 and 1999
- 4.0 V6
- Automatic
- Tire Size
- 31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
- My credo
- The perfect is the enemy of the good.
For the '97. I was going to sell the Mazda, but now I'm thinking of keeping it. Because the '97 is like almost flawless and the Mazda has a few cosmetic issues so I take that when I know I'm going to park in town, a lot of the slots are narrow now and you know sooner or later some jerk will door-ding it or worse. Everything works on both of them, obviously the '97 is nicer (creature features) but there's nothing wrong with the Mazda so I'm thinking it's probably worth more to me than what I'd get for it. Plus having 2 trucks is nice when you want to be working on one of them for a while.
Now to the point of the post. The XLT has 29" tires, but it came with 31" (265's). So I was going to set that back to oem, that will give me an inch more clearance (diff's) and the truck already has 2" lift blocks in the back (oem I'm sure) so 31" will cause zero problems with rubbing or clearance and it will look better and it will set speedo back to where it should be (reads high now with the smaller tires). Yes I'll lose a bit of power, but the 4.0L is real gutsy so I'm not worried about that, and it has the 3.73 lsd so that's all good.
But I was looking at the tech section and before I go out and spend a grand on tires I want to decide if maybe I want to consider going to 33" tires like '96 (I think that's TRS-2, not sure). That would give me yet another inch clearance. It seems like then I want to do "something" to make sure I don't have rubbing problems. Adding an inch seems like I'd only need to add one more inch lift, but maybe I need more in order to clear the fenders. Maybe I need new front fenders. I was looking at the Skyjacker equipment, it's not all that expensive. I don't want to raise it tons because every time I raise it I'm making it more top-heavy (less stable). Then I get into the issue of the differentials (Dana 35 in front). It seems like either I live with probably a perceptible power loss, or, I need to swap out the ratio front/rear and that sounds hard to do if I can even get the front. The speedo gear would have to change, probably the easiest part of it. Cosmetically, I'd probably swap out the rear bumper for black, there's a relatively minor blemish on the chrome, and I think black steel with D-rings looks good and it's useful. Ideally Class 3 hitches front/rear. Winch maybe. If I had a hitch in front then I shouldn't need tow hooks in front, right?
It's easy to get ahead of myself.
What do I want to do with it? I want it pretty seriously trail-capable, I go through creeks, sand, mud, rocks (but not rock-crawling). I think that's like a pre-runner type mod. I'd want light bars or at least off-road lights front/back.
It's the mechanicals of it that are the main concern and ideally things should be reversible back to oem which I would think is possible if I ever wanted to do it.
It has to be good on the street (all things considered since I know I'll sacrifice some there) and it has to look good, i.e., proportional. I see a lot of trucks raised super high, with small tires, not much ground clearance, I can't understand why, and they look horrible. I want it to look aggressive but moreover -be- aggressive off-road.
Right now I'm concentrating on swapping out the auto-hubs, that shouldn't change anything as to plans. And running tubing up from the diff's because of water. Minor stuff but needed.
Chase racks are cool but means tool box wold have to go I'm pretty sure and I like tool box. Again minor.
Help? Suggestions? Something I missed?
I probably missed a bunch of stuff in there. I don't want to hack it up. I'm willing to swap out the front fenders if I have to (should be reversible, I'd think).
