- Apr 26, 2009
- Lafayette, IN
- Manual
That item you found behind the passenger side kick panel is your computer. Without it your truck wont ho anywhere fast as it advances/retards your timing, adjusts the amount of fuel your truck gets ( yes, it may be a carbed engine but it has a feed back carb), and other things such as exhaust emissions. If your state requires emissions testing dont get rid of it. Now some states dont require emissions testing, like my state, or some font require it on vehicles older then 25 years old. Another thing Im told my state use to do was vehicle inpections.
As for the rust spots on the floor those are common on Rangers. The rusted covers that are by your feet give you access to the cab bolts, same as onthe passenger side. the smallers one that are almost under you when you sit are drain plugs (at least thats what I use them for). As for the carpet, I wouldnt put it back in due to it holds moisture against the floors rotting them out unless you put under body spray on the floor first.
