Images of today's work, did some rust removal and primed it up when done:
Removed the driver's side mirror, and cleaned up around the covered areas, and found that the stupid fiberglass or bondo stuff is on the door.
Top Mount:
After I cleaned it up a little, I put some primer on it to protect it for now, will put paint on it a little later.
Came across a bad rust spot under the bottom mount, its bad enough that the entire door needs replaced =P
Got more images for the passenger door:
If you look, NO RED PRIMER! The red primer is on the hood and the driver's side door.
Cleaned it up:
Why is my door handle doing this?
My mirror broke (told ya it would adsm08 =p, the metal was so rusty it would not pivot, and it broke off):
Put on some primer:
Installed:
Got an image of the other side while installed:
Did some bumper work removing a lot of rust:
Primed the bumper:
Did some rear bed work too:
Had some bad spots, this WAS rust, these formed when cleaning it up:
Here is the truck when I was done:
Here is the bed thingy that confuses me as to what the damn material is:
