- Dec 6, 2009
- maplevalley WA
- Automatic
That spacer has a gasket on both sides but they are real hard I just made a gasket to fit between the carb and spacer after I surfaced the carb. Glue a sheet of 200 grit sandpaper to a piece of glass or flat metal and slowly work the base of the carb in a figure 8 pattern until it all shines the same then slowly snug the carb down do not overtighten it. After a few complete warm up cycles snug it down again when the engine is cold. That spacer came stock with many 302s and 351s the butterfly will work just fine and you get the proper angle for the throttle cable.
