PetesPonies
No you are incorrect. Cold air will not help fuel atomization. See what you are missing is the knowledge of how a carburetor functions. What the problem is you have a small engine, that is capable of pulling "X" amount of air into it. A different filter or intake will not force more air into the engine. The air is drawn in by the vacuum created by your pistons. A power adder will force more in, but that's the only way. You now have a hole in your carburetor that is hour glass shaped. It creates the vacuum signal that will pull the fuel out of the nozzle and cause it it atomize. Sense your carb has a hole that is larger than your engine needs, air will be drawn through without a proper vacuum signal created. The way it works is air has to speed up to get through the venturi,. the air moving faster lowers the pressure and a vacuum is created. Since your engine is pulling less air in, the air does not have to speed up as much to get through the venturi, thus little vacuum is created and the fuel, is not drawn out correctly nor is it mixed correctly. This is the vacuum signal that the carburetor creates. You have a poor vacuum signal, thus the textbook problems you are having.
