BichoBII
- Dec 28, 2012
Hi everyone, i bought an 84 bII about 8 months ago, and have been dealing with PO bad repairs, at first i noticed it was running cold, never reached op temp, found out there was no tstat, so instaled a 180°, temp gauge goes to the middle, but then started knocking under load. Then learned a little about carbs, realised my bII have been durasparked, with a 1.21 venturis 2100 motorcraft, and jets where size 41... so started going up (btw, im at around 9200 feet), reached 51 and spark plugs came out black, so went down to 46-47 until plugs were mostly tan, but i still get knocking under load or slightly heavy acceleration. At first i set timing to 10 btdc, but felt better at 12, guess its ok because of altitude. Im running 3.45 gears, 235 tires, and airbox is missing, so breather is taking air right over left exhaust manifold. I know its a bunch of things, but it would be great to find someone with similar setups, mostly jet size for 1.21, i know 1.08 is the correct carb size for the 2.8, but have heard of people running strong with the 1.21, besides its hard to find one here in Ecuador, so im trying to make it run as best with what i have. Any input is very appreciated, thanks!!!
