Missing Bolts - FlexPlate/DrivePlate
RangerDAD
Wisconsin
I have a 1999 Ranger 2.5L SOHC with Automatic Transmission. I sent the block out for rebuild and it came back with out the Crank Bolts for the Flex/DrivePlate. I forgot to remove them, my fault not the shop. I have called the local Ford dealer they claim they can not even find these bolts in the system??? There are six bolts. Can anyone help me figure out what size they are or provide a Ford part number, that would work too. One lead I have is; M10-1.00X30.0 I am not sure how to translate that at an automotive store for hardend bolts.
Any help would be appriciated. Thank you.
That's a fairly easy one...
M10= 10mm
1.00 = Thread pitch
30 = 30mm long
So if you take that number m10x1x30 to your local parts store they should be able to hook you up. I can't remember off hand if they use lock washers or a special bolt head to lock these bolts in place, but I would think you could get away with lock washers on a standard head bolt if you use a little loc-tite on the threads. Use the Blue loc-tite (can't remember the number, I think it's 284 or something).
