"Mini Me" Low COG B2 Crawler/Jumper Build
Coated the exo in STEELIT, weldable paint.
B2 got sent off for Vinyl windows to be made for the 3 rear windows.
Started painting the jambs with my final color. Turquila Monstaliner.
Sanded and coated chassis in STEELIT.
Got swing steering powdercoated.
C clip eliminator.
New beadlocks.
Center console time.
Hell of a lot of work there!
First
I expect that challenger back home in MY garage by midnight young man.
Have no idea why you think it should be out there....
I definitely would have used a rear 60 and a front ttb 44 to avoid notching the frame.
The exo being removable is superb! Wow.
I would have put it in the fenders.... But that's some good work.
Yup need more tube over the forward roof though and some sheet
You can use a 31 spline slip yoke from a 2wd trans for the passenger side.
Cut and sleeve to extend.... Or if you went to a 50 pig or 44...with the 50 yoke...it can be a 1350 joint.
First
Challenger is my buddies. I was fabbing up some stuff for his hellcat swap haha
I had these axles mostly already setup snd i wanted a small track width
Im gonna do a bar across the lower Windshield snd then windshield bars.
Exo was removable only till it wasnt haha.
I modified the width of the axles and trimmed the splines. It fits just perfect at full droop and at full bump. No binds and no chance of coming apart. Took a little bit. But ill add your info to my notes for next time
Photo dumping, never realized I didnt keep this updated.
