"Mini Me" Low COG B2 Crawler/Jumper Build
AM-JKLWOKXMp-rpw6qlbOT7PdwN3xFGcjyJAHaYgcYejDjSymAr7LJUp4HCjTBNGeGArIiGs1zhMCmNeW7yBQ94Ld7TRQViqlipHw2yYgfDWm8iAzYzHU8ZRmMV9jveNAiJ6a-Su0RqTm6rrPEhaEADwA_CFqQ=w1920-h909-no
AM-JKLUQEj-Nnd_SQ1BZkhnjBRKi_1Imr_7yD3Lv8qcwCrpJDPazrxspuvlV7pQGqLgTrmw3ZZwYPbyC3r66mjJ2ebhtAUK2SG0xVyZ_nYSEvJB6m1y6hvi4LX0kBqmzatiBKqufMV62Xu0OHvHYAzc_0wFLLA=w1920-h910-no
AM-JKLUBWzIlMPWEoYuk4c2ihG3ljgE4auiMX3zryThUc0Ckg3yzL0tQJm-YQLOeksD1FVYuISZ7WZcyEL3JJM7hp3yJe-8135JoqTKpKXR_o_ICCW0SwgzwB79FWK3T5RNVDt3ZpkW538qnph_mVP8heTRu2Q=w1889-h947-no
AM-JKLWZ8PR6iXaTFFgjEti5h3g5-aQET9MpFtHehZUtj8gDTkP1jZE0512Wu_weUS-pxY8ZPC8pFhqsArgAV6ll6_L0XmynRPkZ22Uy815UTASJHknmSazgzexx0irCh3cwUyIq6WOECtec-DOfp1hjM_7Zlw=w1920-h909-no
AM-JKLVo9AdaJ1LxHhmEBsq1AvUT4gQH2STeOJC3ojMlVfQ5CE1fHydAnUK43TLlO0ggRSq1SF-VMeW54h9jgpjs8oQ_VMu57k-UGM9YoRo31SwzCVdEkvRNnLcuen3Fdo0VwhxEihrc7a7itX996LfuD9vrzA=w1920-h909-no
Coated the exo in STEELIT, weldable paint.
AM-JKLUnRYlG3ogzGFD5luqM1yGfdk-jWdhg1kVT8IQApRreZys0Qr2Xmr-oBZYVmFrmnZs_T_S8NC6n7K0SLWFG3VFGvjSqbfgq1QFvkqscOGKpR3u2VuRV6Avwoh6S-1UjxFuQ_SNzQjyiPZK0BxFQAhq6sA=w1920-h909-no
B2 got sent off for Vinyl windows to be made for the 3 rear windows.
AM-JKLV-u97n5AZlBVE6I_aR6ofjXJ08RrprN8-T7nfzrpNSYxF-TGx1ssngz3mypifKRcuL4UVue9FtrJzyYwWoaOq1rVQB6cifiGETwoaJldyKgn2sWtDJn0-O37G56dLK8WvubwJh1GI8L0KlWOpoiutBQA=w1920-h909-no
AM-JKLXkGmoczyYJ03sXsPXebRL7LG1FOqq0zXSX1Tlg5w6qpD_Z6w6OpBj2-XM1Hw3NADZt8G6yYWLvFZN2pgk8hJtHNqzOHcu19cAuhq0J8_hWyH8ulZmiYtOyOC1lJYI_8btFLFBXkkPBkL1CX9y0i1BlFA=w1920-h909-no
AM-JKLXVCiExtY_k091YOUK_2vj0hZjHnG8vJ1d7wCsbM4TM5LsVC1AvbZjIwIhgJLUm9WNLyoGSecdCzn_vbQ_MG5nKrVh1DCbjXvBFFu8F7F8FSVb_VOfe2QpfNzAFjeWDgNLlUcf28i4J83ckXY3912Otnw=w1920-h909-no
AM-JKLVbf792P2htvpGliSyKM76Zi38pDtjCUggbJmPa7YFNv2nlAhA0JWd28vfLxgOTif650HuX7ovJLyyrTrXj5Ay5pH9aSWqVx43dqDXgbbUABA2p5t0ilcEjRG7a-mGwhXyVdhfTnpRz4Aj43VGRC4mBPQ=w1920-h910-no
AM-JKLU7bjObPcPE4RIzmRlV0vk3yWHsLMgPaQowUor-w-oKCcs2X7A81KxbBtNBiVEzcucpcHyN2wefjWCTXQesfAvAcvJNLj0sZnuaFbIylanyNlOgSPzFtw_V-89Uxyp84OK_Q4JR5EX0sO3NIkBB6J0vdw=w1920-h910-no
AM-JKLV2py5FnxuTm8-6ZCKEUCC0dcN-B6vg_wCZx8LOO5crxd1E9GPZxcSI6NSHjmWhA_juBwClyEkf6v3xkZjRy798qS4uyoRUh8PbQ5yiOv17SE6a7sqVY02ASoAzBmYJmXybzdxTit8nFtnkfHc2V_rlGQ=w1920-h910-no
AM-JKLWrZ9MmPTBg8JdStFfURAFczNZDJ7sKeWoqGOJ-AushRez3Sfr5tuYZ_Y3fbbQz-abGA0e6vbE4BI6Djd2TzLNVrEPRp5EsRHuF3KYmTUGBtvOetQh8m6bnuks-xc0A69HkPgCNj7i-q5lUxcIZ4oQgog=w1920-h910-no
AM-JKLVd4Vf5U50fL4g2Yd83p93G3qXE_E8mlpdEcm_V3DIq9arpI9pC0nBptZl3bmbZOAb5jBni4P8zuWmN3Gv8Vl0MgkKn_05iLkxg7AigfsJ60NASw-nNWkJqx9OURp0Wh_8KDUmW6uLKAtPbHsXaJrbB1A=w505-h947-no
AM-JKLVsieJ-JNhuQvinCcw0ncmacdzOeb1Zou7PxK324yheBU85mesOnxt2OzhpH9clA_ZWdqTcZHVhlnet7lbh_x_ufzsWEGGM0sKptWJQZJfjKp7dhq__w3gqsLpCa6ko0zLC98UEZ0-VF0owAwwnKb_hyQ=w1920-h910-no
AM-JKLV6vpdjs7DpVRm0gcEH2-WPnbPFc9G4O984ra6Q0_r00xTg1toFv8Q3IRy_KBnGmv0ymEZTVe2RW-gtxTkcuEDPdER-yYR6JS3A1D0S-7JhuZeQyPLVYszqj3O2oSI0_vDCvDDWzzxI2lXBtdbJ86UKRQ=w1920-h910-no
AM-JKLXYv-X3trXdN9B7U5lRt7CS4SCGFwAceUZsri8QKBJI5slkfdgQqUI6BWzYKRLvAujXd7Nnts5W4W7e7nUr1Sko6yQnIfwLWRRAehGL43btM6nC_I6UO9_2XKcgg2Aa6_D2FLpJXTC6BdOaqZ-acYv_PQ=w1920-h909-no
Started painting the jambs with my final color. Turquila Monstaliner.
AM-JKLUsZwx7Y6J-mxRUUHvSV62jjhqSVaWqs_EgqmfslZXvb5EeKwWeD2NaB7UHFKci3wclVeXC2haA8PlodQYh_z7JT_jABmDccx8ftX0cMXNGmjaQHmYihGG3N2WSuBgUH317yT4Dyf_kVjEHlTdPBHDTpQ=w505-h947-no
AM-JKLXiGs2q5N-5Xse6oTT23elRjPsKz4SAoc_lLYpqzCGkxg2i_yX9slqSh5Xk0hhdkWv51UCO5Wz5sGKkqv0w1sqLIa4csUfV23LgFpp-UZ40jbCPl7i-sHQvIRo0B0XNs5iN9vXCRkPZfzE3Ck-7XeHkhg=w1920-h910-no
AM-JKLWLmp0Ofn-jYBkX1JdvcHjyJe1Dcj5Wh4jNVOzEiunTYO51eg0WnK10u4Oj_V6_xEemKinoRjh3Uw99fUhCWZTnYFEHM_wSiHxrkfoAL9g0v1GlrsmtVUK6Hwfq6xykaGaLtoYRTVBWnf3-AgemLURQGw=w449-h947-no
AM-JKLVlwQ_awlbcO7guULn7bCU9vGC3QAI2SxBY3DLX49Da-ezbpxP--k4vLQc-t-hQVhpja6WlYcObiGyDSeFuw_tahav0c5Ykk4KAOawPmdoehL3GLsYdCH1bjw2wvgmlJqhBoLiGmhsgGta98vPVdTxvkQ=w449-h947-no
AM-JKLX35Iljbl9A7RELuIR101hI4xeGbzsA1ZK9g4gjQNsfUbNJTADyLmD4r1JnDoH1vW5-mxmBskIVG4kzAHSzT9_MenR2J0QUKb0xvnwIToeSauqJWxWQXqYa5q3eC4JcXp9R2YvX-ixgrTCeJQ_ULHgeeQ=w1920-h909-no
AM-JKLVqSzpgS8Ny7MW82BU5wKSSgKIqKL0jjsqxD0abpoavar79IUXsG0KqazXv2RV-p4H6dSRcMnvt9K3mEvB8E9jiIQTm23iry3U1fsGuqTu3HLfeq8GmmYzMwZPgKce5wK3bsSKIgXmTORYSrqqpW3quIQ=w1920-h909-no
AM-JKLWvNHLJBsJTy14_WYZcp5rjDRJQtYBhN7V37OivPx3gje82L_5PYMiUvQ_kig_ksBhJokC565hPMEsRV2iS31zEyCpG0aBHxpn-RTzmA1Nur6cBfUlojRTYX0FWl0wciJFurp2T3PblN_472fYtEyYi3w=w1920-h909-no
Sanded and coated chassis in STEELIT.
Got swing steering powdercoated.
C clip eliminator.
New beadlocks.
Hell of a lot of work there!
First
I expect that challenger back home in MY garage by midnight young man.
Have no idea why you think it should be out there....
I definitely would have used a rear 60 and a front ttb 44 to avoid notching the frame.
The exo being removable is superb! Wow.
I would have put it in the fenders.... But that's some good work.
Yup need more tube over the forward roof though and some sheet
You can use a 31 spline slip yoke from a 2wd trans for the passenger side.
Cut and sleeve to extend.... Or if you went to a 50 pig or 44...with the 50 yoke...it can be a 1350 joint.
AM-JKLVjqSg8xPHPaYXRbH-H_H3yv9ZhkWDFNVm8iDthX8KSR7lkHU3D6owX_fTi8Ordf-W5rGmG6TpbvjgILAsO5WpbuYS7hd-U4KAthYIrisJmMcTJR4hdk3w1mSjuxTgQaCH5ujP6obxSqYJvjOfX3xOZlA=w449-h947-no
First
Challenger is my buddies. I was fabbing up some stuff for his hellcat swap haha
I had these axles mostly already setup snd i wanted a small track width
Im gonna do a bar across the lower Windshield snd then windshield bars.
Exo was removable only till it wasnt haha.
I modified the width of the axles and trimmed the splines. It fits just perfect at full droop and at full bump. No binds and no chance of coming apart. Took a little bit. But ill add your info to my notes for next time
