manual tranny swap
fishman3
Hey guys I need some transmission help. my 1990 ranger 2.3 2wd man. tranny m5od-r1 is about gone. no reverse or 5th gear. I have access to one that is under a 1990 2.9
4wd. looks the same. can i take the transfer case off and put my 2wd stinger on it an make it fit?
Won't work. Cases are different and the bellhousing is part of the case itself. Even if it would work the mainshaft would be to short for you.
if you completely disassembled them you could make one good one, but that's probably deeper than you wanted to go...
If the main shaft is good on his.
I have a 2wd 2.3 trans forsale but I'm in Michigan.
Done. Lol
Sent from my HTC using Tapatalk
