- Oct 21, 2017
- Automatic
Hey all,
I have a 2002 Ranger with the 3.0L engine. The lower radiator hose was leaking at the tee, and so I replaced it. I used a Gates hose and used worm clamps instead of the spring clamps. I tightened all of the worm clamps with a screwdriver. I'm now getting a leak where the hose connects to the bottom of the engine when the system is pressurized. I used a small socket wrench to tighten the worm clamp down as much as I could, and the leak didn't go away. So I then tried tightening it slightly more with a ratchet wrench, and still no luck. I can try tightening it further, but I'm not sure if I'll just end up breaking the clamp. I was wondering if anyone has any suggestions? I'm not getting any leaks at either of the other two connections.
Thanks in advance.
Thanks in advance.
