Fordmommy
- Apr 24, 2015
- Automatic
OK I have a 2001 ranger xlt 3.0 v6
She was very loudly squeaking and squealing at pretty much all times, at startup, and while driving and at idle. So we replaced the idler puller and belt tensioner. Still the noises were there. Discovered the water pump was leaking so we had to take it to the shop due to work schedules and no time to do it ourselves. The shop replace the water pump, upper radiator hose, thermostat, and the tensioner (the entire unit) again because they said it was bent up a little throwing off everthing, and a new serpentine belt.
So yep you can guess all of the noise is STILL THERE. Now I am getting really annoyed with them at the shop and before I blow up on them I want someone with good knowledge of the trucks to see if they can figure out what it could be. I dont want them to fix or not fix anything else but need to figure out just what the heck is causing this noise. Oh and there is also some white powder formed on the serpentine belt but of course those people got antifreeze all over everything when they were working on it so not sure what the heck is going on with the truck but help would be appreciated.
