2011 Ranger PU, 2wd, 2.3L, automatic, 23,000 original miles. The truck has a Loud, light metallic, (apposed to a heavy metal clunk) noise when making left turns at slower speeds as in making a left turn from a stop or a left U-turn. A short version of the same noise is some times heard when driving straight at 30 - 35 mph over bumps, such as railroad track. Oddly, nothing on right turns. When the noise occurs in left, right angle or U-turns it is pretty constant through the turn. The noise sounds like it is coming from the entire under carriage.
Steps taken to isolate the noise:
- Bouncing on front and rear bumpers; suspension feels/sounds solid
- Check brake calipers for rocks and repacked the wheel bearings
- Checked spare tire for snugness and the truck bed bolts and bushings
- Transmission cross member and mount are tight
- Used electronic ears connected to multiple locations to pinpoint the noise; seems to be from the bell housing
- Removed the starter and the noise was louder, with and with out the ears
The transmission shifts smooth and no leaks.
My thought is possibly a cracked flex plate, near the bolts as no visible crack viewed through the starter opening and the teeth look good.
I have never had a torque converter go bad, but it seen I would feel that rather than hear it. I did not yet check the drive shaft U-joints.
The Left turn thing is odd, like something is loose and flexes in the turn and that would not affect the "flex plate" though the noise seems to be from the bell housing.
Thought I'd ask what you all think before pulling the transmission.
Thanks for any ideas or advise.
