seanm
I am having problems with the charging system and so I started following the charging system checklist from the tech library: http://www.therangerstation.com/tech_library/chargingsystem.htm
Unfortunately, at step i, the light does come on. Disconnecting the alternator harness did not solve the problem so I did what is recommended in step 3b and starting pulling all the fuses one at a time. (I assume you are to pull them one at a time).
I pulled all the fuses from the panel inside the cab and only the radio fuse made any difference. When I pull the radio fuse (fuse 29), I get a roughly 1/2 second clicking sound from the center of the dash. The test lamp pulses in time. I am not certain exactly where the sound is coming from.
If I reconnect the battery, the radio does work.
Any ideas where I should look next? And ideas what the clicking is?
