Lill Mule 89 BII
pretty cool looking truck man
Ok so the front pig is not leaking! That is really good news. Looks like oil was coming from power steering pump and engine. one less thing to worry about.
I really want to make time to get this engine in and start this thing up! I am very curious how much more power I am going to have with all 6 cylinders running instead of 4.5 cylinders.
got wiring harness all swapped over. everything matched EXCEPT for 1 wire going from the drivers fenderwell to the engine. The wire does not exist on the 92 explorer 4.0 harness. I was going to bolt the inkae manifold top on but I cant find my tube of black RTV. Will have to pick one up tomorrow so that I can put the intake manifold top back on.
going over the 93 4.0 motor I cant tell where the extra wire went to. have oil pan, oil pressure, transmission neutral switch and reverse light all hooked up. Just one more wire that I cant tell what it goes to as all the sensors have a wire hooked up.- after about a hour of retracing everything I give up . too tired after a long day. will attack it tomorrow.
A friend of me is giving me two jeep roll cages. So that will give me metal to complete the front cage. Trying to decide if I should exo skeleton around the cab or not. Not much room in their right now. A exo tied into sliders would be pretty good strength move. Would have to decide how to tie the exo into the rear rollbars.
got some RTV Gold and put the intake manifold back on . finished buttoning up the rest of the hookups. Looks like the wire I am thinking about is a extra that was on their previously.
Measured the clutch disc and it is at spec. so looks like I am ready to put the motor in.
Got a phone call that the guy who looked at the explorer sport yesterday wants it. so I will be getting a manual 1354 this week unfortunately without linkage, . will have to either build on or buy one. Maybe the linkage from the manual 1350 fits? I want to do it all at once so it is a small hiccup to wait until the manual trans is in.
Found a small oil cooler at a garage sale a couple weeks ago. Looking at return line for power steering pump , the line is the same diameter. The existing line needs to be replaced. So think that I am going to run a couple of 3/8 lines up to the front for a power steering fluid cooler. Mainly prevention for the trail.
Now if I can bug my other friend about the electric fan i could get that in now while the motor is out.
Starting to look at the existing rollcage and measure it for more bars and rock sliders. :icon_welder:
only about a hour and half today to work on the bronco
swapped flywheel and clutch over and got it lined up. the old flywheel was really messed up. it is a near new valeo set - cover, plate and the throwout bearing looks new also. Motor is now ready to go back in.
started working on putting in the power steering pump cooler. Cut the return line, flared it and then put a hose on it running to the front. ran the other ran to where it is supposed to be. thought I had hose clamps to put the hoses on the cooler but NOOO I bought the wrong size this morning. grr will get hose clamps tomorrow morning. will post a picture of it when I am done.
trying to decide if I should pull the dropped pitman arm and have my neighbor reweld it 2" lower
local junkyard says he has the linkage with shifter for $35 will have to pick that up tomorrow.
didnt make it to the junkyard - too many farm tasks to do
motor is in and all hooked up, all thats left for motor is to run ground to block
got tranny in and bolted up, cross member, starter, y-pipe - 3 of 4 bolts went in fine. 4th one went in fine half way and then got tight.
stance is pretty good - front is sitting about a inch lower than it was before. not bad at all.
trying to hook up with the guy who has the manual transfer case to do the swap so I can finish everything off and drive it!
loading the Explorer on the trailer so that I can go get my manual transfer case tomorrow
pics of the manual transfer case - he threw in the front driveshaft as a bonus
along with the long travel rear driveshaft that was custom made.
also picture of the manual shifter - they gave me everything that I asked for. even the bolts for the going into the case. plus the shifter boots - all this for $35
IT RUNS!
so happy -no check engine lights either
attachment.php
attachment.php
decided to just buy the correct 1354m shifter and linkage
I test fitted the 1350 linkage it is 2 inches off. Was looking at what it would take to create a linkage.Can create it but the correct linkage is only $60 shipped to my door and I can sell mine for $30
drained transfer case and transmission. refilled with fresh mercon. filled radiator up with water for the moment. (I might put a 3 core auto EX radiator just for fun.)
Threw battery in, MAF sensor and tube and fired it up. can already tell it is running better by how much louder it is.
Need to bleed clutch as it is not disengaging. might be able to drive it tomorrow :icon_bounceblue::icon_hornsup::yahoo::icon_twisted:
bleed clutch, changed oil and filter, filled up power steering fluid, checked radiator fluid.
started it up and drove it around.
Lots more power! took a moment to relearn idle. once it did would chug along at idle. did not do this before.
the 4" jeep springs gave lots of flex.
BUUUUUUTT they are way too soft. sagged almost 3" tires are 4degrees camber in
SO pulled the jeep springs out and put the stock SkyJacker 6" 450lb in springs back in.
Also made a quick disconnect pin out of a bolt for the front swaybar. Just did one bolt. might do the other side also. Need to figure out how to hold the sway bar up when it is disconnected.
spaced the shock out on the passenger side as it was hitting the front beam.
pretty stoked - no leaks and the motor idled down very well. Lots more power ! just need to get the 1354m shift linkage and I will be ready to drive it for a while.
more flex shocks - skyjacker 6 springs
now some flex shots with skyjacker springs and sway bar unhooked. you can see that the front does not like to stuff as much as the jeep coils. still stuffs the rear wheel very well. Rolled the rear wheel well after these shots. Looks like going to have to cut the rear fender well as rolling it is not cutting it.
rear wheel is off the ground
sway bar disconnects
ok while looking at the sway bar and I had a brillant thought. why not just cut a groove in the bolt and put a hitch pin on it ? pretty quick and clean after it was done. Only problem was getting the hole to line up again require my high lift. Which is not a bad trade off.
Dude, NICE! I wish I could work on my B2 everyday. It's real fun once everything comes together!
helps when your unemployed :annoyed:. I also don't watch much TV - try to do a hour a night on the bronco if I have a project on it .
I have noticed that the 1st gear on the m5od is not as low as the FM146. have to use more clutch.
I do have a line on a shifter for the transfer case. Having a hard time finding the shifter pawl from the transfer case. hopefully stuff sells on ebay this week and I will be able to get my shifter.
I took the glasspack off and put a real muffler on it. much quieter but I cant wind the motor out as much. So i will switch it out to a more free flowing muffler when I get some money in.
I can hear more squeaks and groans not that it is quieter. It runs very smooth with a lot more power. Really nice to just let it idle down and put along.
