lift problems
austinhaynie
I put 2 sets of 1.5 inch coil spacers in on front coil springs to give it a 3 inch lift. Now I have bump steer that pulls side to side on highway. Do I need a drop Putnam arm and if so how much of one? It is a 93 ranger 4x4 has had alignment after spacers were put in.
a 3" drop pitman arm will help, but not totally correct the bump steer problem. noting will totally eliminate the bump steer, but a pitman arm with a drop equal to the amount of lift will get the closest.
stacking spacers is never a good idea!
Alright man thanks I ordered one yesterday think I'm gonna just buy the 4 inch lift springs
you probably need some drop brackets for the beams too, especially for 4 inches of lift
Yea definitely and I'll check into drop brackets too.
yeah, 3" of lift needs drop brackets and a drop pitman arm AT LEAST.
Can you send me a link for the drop brackets not sure which ones are right
alright preciate it trying to get some $$$ first but already ordered http://www.autopartswarehouse.com/sku/Ford/Ranger/Pro_Comp/Pitman_Arm/1993/E37FD400.html?apwcid=productads&003=27846857&010=apwE37FD4001993forapiar&gclid=CPXMyezl87kCFfFj7Aod9X8Afg[/URL]
