lift kit question needs answered asap
will fit no problems. the only thing may be that they are softer coils since they are for a lighter truck. double check everything is there before you buy it. don't want to get your truck torn apart and realize you are missing a drop bracket or something.
Going off the top of my head, it should have:
Axle pivot drop brackets
Radius arm drop brackets (assuming it's not an extended arm kit)
Pitman arm
coil springs
Swaybar end links (or drop-down brackets for the swaybar)
Rear lift leaf springs (or blocks)
Hardware.
Extended brake hoses generally are not included in kits for some odd reason, so plan on getting those if he doesn't have them.
