Lift coils in a ranger - how much lift
racerjamie
Manitoba
How large of a lift coil can u put in a stock TTB 4x4 ranger, Is it 2.5 or can u use a 4" coil?
Thanks
I think it is only 2.5", any more than that and you can't correct the camber without puting in lift on the piviot end. If you go 4" you are going to wear the crap out of the outside of the tires.
yeah i think its just 2.5'' unless you are doing an entire lift kit. chances are you will need new camber bushings to correct it after the 2.5'' coils
Ok, Thanks, I think i will probably go for the Skyjacker 132x coils then. It will probably look alot higher as my factory front coils are touching each other just above the middle, don't know how, they arent broken, and it not like that anywhere else on the coil.
Featured Ranger Based Vehicle
