Left Upstream O2 Sensor Removal
FACTS.
I spent all afternoon Saturday getting my lawn tractor to run again.
( I HATE chasing electrical gremlins. )
Worked my 24 yesterday.
Technically today was supposed to be lawn mowing day...
It also doesn't help that I have been out of my ADD medicine since Friday. šŸ‘€šŸ¤ÆšŸ‘€
My lawn/garden tractor has messed up steering. I took a stab at fixing it back in the fall and my attempt didn’t work. I started making modifications and then winter hit and it was no longer a priority. Now for as much as the grass/weeds are growing and as wet as the ground has been, I’m thinking time is better invested getting something that can handle really tall stuff fixed. I have two 5’ brush hogs and both need work. Spent two days hand filing splines so the new stump jumper fits the 3-point hog so it’s finally almost ready for me to finish putting the underside together, set it down, and deal with whatever I have to topside to make it work. It’s been standing on end since fall…
I really should probably service the brakes and axle bearings/seals on the farm tractor but I don’t have a shop press. HF just had their 20-ton on sale but money is tight as usual so I still don’t have a press. Not that my shop is done enough to have a place to put a press…
What is this sensor that plugs into the side of the transmission?
It looks like it is held together by a c clip.
If I could get that wire out of the way I would have a little room.
I believe that is the Vehicle Speed Sensor.
It's the gawdayum clutch slave cylinder fluid line... FML
You didn't mention it but maybe you already tried simply running the engine long enough to heat up the exhaust manifold. That's probably what I would do. Once upon a time I put a large pipe wrench on an O2 sensor to remove it. It crushed the sensor a bit but I was replacing it anyway so it didn't matter. Good luck.
Yeah. And let it cool down enough to not burn TF out of my hands!
Another hour and one broken gear wrench later...
I put the wrench on it, wedged a 2' breaker bar between the jaws of the wrench and the exhaust pipe, and leaned on it until I heard something crack, then leaned a little more...
It broke free, and the pawl inside the ratcheting end of the wrench broke too.
It was the "Husky" brand from Home Depot and they warranty replaced it so it's better now.
Took the truck for a test drive and after the second start / run / stop / start cycle the CEL came back on. 🤬
Threw a P0135, Bank 1 Sensor 1 heater circuit.
I'm guessing I didn't get the plug on the passenger side upstream sensor seated all the way or I pushed one of the pins out of place.
That will be an easy fix on Wednesday... šŸ‘
