IIRC the 5.0 was batch fired until 1996 OBDII days
but a TFI 5.0 ecm can plug in place of a 2.9L ECM, and 2 injectors then need to be soldered into the harness,
aside from that, the sensors all have the same connectors, the same connector on the TFI distributor, and everything. it's a pretty painless wiring setup
Going have to do some reading on this, I hate wireing, the truck is a 97 3.0 that i'm wanting to swap. So on the wireing, can I not use the stuff that is in the f150? or is it going to be a major pita to do?
For
