- Feb 24, 2009
- Age
- 37
- Saskatchewan!
- Automatic
That's why our D35's are so much stronger than a Jeeper 35. But we have u-joints to worry about.
Well if they warranty my gears I'm gonna put them back in a run em, maybe build the HP on the side. Just not sure if I wanna spend the $$.....I just wanna wheel!
I just wanna wheel!
Negative, our D35 is "stronger" because it's a front axle and doesn't do all the work a rear axle has to do. A low pinion in the rear axle runs on the drive side of the gears, this is what you want, a low pinion in the front axle runs on the coast side the gears, high pinion fixes this. Custom high pinion rear axles run on the coast side, making them weaker than a low pinion but provide better ground clearance.That's why our D35's are so much stronger than a Jeeper 35. But we have u-joints to worry about.![]()
if they don't warrenty the gears....build ya a HP 44......
then sell ya LP to me cheap......
l8r, John
You got a deal. I will have about 75 into the HP with gas so you can have my LP for the same...is that cheap enough?
Stripped the front axle of it's gears today and shipped em off for warranty approval. I hope they cover them.
So here is my plan, may change, but as of right now, I am picking up a FW HP D44 tomorrow. I am thinking of just leaving it full width and removing the spacers I have in the front, so I will be about 1" or so wider in the front than I am in the rear.
Only issues right now, I need a new carrier for the HP gears, they don't sell thick cut gears for HP to correct like the LP. ~$65
Need to buy HP 4.88 gears ~$178 for yukons
I need to buy 6 weld in bungs for steering and track bar. ~$44
I need to fab a new track bar mount for the axle and new longer track bar, drag link and tierod....so 10' of DOM ~$60
then maybe one chromo long side shaft ~$130
So a total of about ~$477 then shipping.
SO would it be worth putting the money into the HP or just leave the LP, replace the gears, if not warrantied, ~$220 then just run it and save for my 1 ton rig?
what do ya all think??
