- Jul 6, 2008
- Monument, CO
- Manual
Alrighty I'll keep you all updated. I got the ballistic parts, synergy and ruff stuff parts.
My buddy ed had a spare front end in his bone pile with some of the outer stuff I needed. Spindles, brake parts, axle shafts. I mostly wanted the spindles as they are so hard to find. I also ordered an empty carrier. I also bought a new set of rotors rather than have the old set turned. I plan to use later ttb hubs because I found the warn lockouts fit much better on them. The axle I gutted had some scary steering and it looked like someone had started cutting off the cbushings with a grinder and a torch and given up. I am suprised it held up with the barely welded on spring pads. I would guess someone threw it in a cj at some point. Here it is post gutting:
