Just Plain Stupied
O.K.
no beams at the mailbox yet.......
but I did yank the grill off to do the electric fan thing.....
also yanked the radiator & dropped it off to get it boiled & a few leaks fixed....
I'll post some pics of the "minor adjustments" tonite before I start putting stuff back together.......
that oughta take care of the overheating problem in 95* + heat & stop-in-stop traffic
O.K.
95 degrees? When does it ever get that hot in loosiana, DeeGee you dun did lost y'all marbles!
N0-0-0-0- sweat...
don't need no stinking marbles...
as long as I got wheel bearings...I'm O.K.
:icon_bounceblue:
PiCs....................raised the hood(s).........30 seconds
removed the G-G-G-G-Grill........10 minutes
removed the A/C condenser & radiator & trans-cooler............20 minutes
V.A. meds ......................can't live without em.............
caint think with em.....................
Friday.....went to the pik a part & found a fine elctric dual fan set=up with shroud for the radiator.....
forgt to measure the lenth (don't need no stinking "g" in that word) of the radiator!!!!!!!!
the dual set-upis the EXACT width I needed......
but it's 7" toooooooooo longgggggggggggg....
gotta go exchange it Monday....
RATTTTTTTTTTTTTTTTTTTTTTTTTTTTS
I was gonna hve it back together this weekend....
I'm so upset.....I think I'll have a sammich & a med..................
:icon_bounceblue:
i think i'll go take a pic of the fine dual fan set-up b4 i return it though....
Later.......................
So no 3ft objects sticking out your mailbox yet?
nope....................I eeeeeeeeeeemailed the dealer to see where it is (at)....sumwere between here & Kalifornia......
I think it would be easier to fix the truck and track down the shipping truck and take them out and drive back home and instal them.
Basiclly take stuff into your own hands.
Yore problly right!! Ther's always gonn be sumbody sittin on his hands somewhere.....
lectric fans everywhere!!!!!!!!!!!!!!!!
now....I can put 2 pushers on the radiator....
or.........2 pullers on the radiator.....
or......a pusher on the front of the radiator & a puller on the back of it....
annnnnnnnnnnnnd a fan on the A/C condenser which will be moved into the engine bay to allow water pump clearance for the radiator/fans....
naaaaaaaaaaaaaaaaaaaa.......
And one on the inside of the truck to have a super AC system and also for the cooling/heating cup holders.
memory like an elephant!!!!!!!!!!!!!!!!
.........got no work done on the Ranger.........
had to spend the day at the hospital with future son-in-law--
torn ACL--surgey went O.K.--
but he's hurtin b-a-a-a-a-a-d!!!!!!!!!
some news on the drop beams that I odored......
1st......the bad news......
the beams have been on back-ODOR for 18 days....good thing I didn't yank the stock beams out from under it yet.......
now....the uhhhhhhhhh....good news...the beams will be boxed up this coming Monday.....
I MITE get em by Saturday....probabobally......maybe....for sure....
I WON'T be sleeping by the mailbox!!!!!!!!!!!!!!!!!!!
All-right............
took the Ranger for a 120 mile spin to check out the radiator repair/eeeelectric fan install......
it ran cool as could be.....the 180* temp switch from Jegs worked just right--Fan On at 180* at traffic lights--Fan Off at 170* between lights :yahoo:
the only drip came from the old lower radiator hose where it connects to the radiator...I picked up a new hose on the way home :yahoo:
EDIT: Man.......that engine bay is quiet without that mechanical fan roaring....I can hear the carb pulling air thru that dual-inlet air cleaner and the exhaust popping at idle.....the electric fan only comes on at long traffic lights in 85* temp!!!!
Plus should help with fuel mileage too.
uhhhhhh......danger_.......you speelled it wrong.....it should be PLUGS....
PLUGS should help with fuel mileage too.
want some of my meds....(pysch!!! i caint give em to you..it's aginst V.A. rules....no sharing)
:icon_bounceblue: <<<<<<that's me if i forget to take em...
:icon_surprised:/:icon_bounceblue: <<<<<thats me if'n i take em...
Event Coverage
TRS Merch
