- Jul 28, 2010
- Automatic
Am I the only one that thinks the seat looks entirely too close to the steering wheel? Awesome looking truck BTW. Its gotta be a pain to steer rapidly with the wheel that close.... right?
i have no links to share. my tuner got me in contact with a guy who did it. i will be making a DETAILED thead with lots of pictures and all info once its running.Any info you care to share or links on running the sohc on OBD1?
NICE WORK ON THE CAM SYNC. i knew there would be a way to do it, but my tuner said hell just tune it out so i forgot all about it. let me know if you got it and want to sell it though! id probably put it to good use!Another thing you have to watch out for. The OHV and SOHC crank sensors use the same connector, but the wires are reversed. (Depending on the year.) When it’s all installed, if you have no spark... de-pin the crank sensor plug and swap the wires.
If you “just tune it out” The ECM won’t know if the cylinder it on the compression or exhaust stroke. That’s fine for the wasted spark system, it fires at both times anyway. BUT, how will it know when to fire the injector? It will have to batch fire the injectors.NICE WORK ON THE CAM SYNC. i knew there would be a way to do it, but my tuner said hell just tune it out so i forgot all about it. let me know if you got it and want to sell it though! id probably put it to good use!
and good note on the crank sensor. i have the wiring diagrams for both vehicles and checked that out. my combo is pinned the same so im good there
the top end is a little wider and i did read he had to modify the heater box. i dont have any of that to worry about as i dont have ac or heat.Isn't the 4.0 SOHC wider than the OHV? I think @RacinNdrummin had to modify the heater box in his Bronco II, but this engine came in the 2001 Ranger, so I wouldn't think there would be a clearance issue in the 1993-2011 Ranger.
