SRD
- Jun 18, 2021
- Las Vegas
- 3.0 V6
- Automatic
Hello. Ok, so I have had many of the same codes popping up over and over and over for a while now. One drops...one comes back....but always codes.
*Codes:
*P1409
*P0402
*P0455
*P1309
*So. I have changed the DPFE 4x with no luck, had to put back the original metal one to ever work. Changed the EGR, even took a speedometer cable and cleaned out the line with a drill and sprayed it with carbon cleaner etc...I changed the fuel pump, the starter, complete tune-up, new cam sync and all 3 O2 sensors. New fuel cap, and I even changed the vapor cannister. ZIP....
*So, I got notice I had to get a Smog or else......so at Walmart I bought this product by chance. I filled my tank to the rim and added the whole bottle to the tank. Soon as I turned the key to start the truck the Check Engine light came off? I drove it 80 miles and PASSED SMOG.
*In Neveda you can fail one test to PASS. The EVAP takes long time to set the guy said so it can fail as you get one FAIL. So, The EVAP failed but I PASSED over all so got the certificate. After 280 Miles the OBD2 said the EVAP was now GREEN LIGHT and the I/M Readiness Test all Green Lights (never once before have I got this). Once it passed the I/M Test I knew it would pass SMOG also, right?
*So, is this some kind of "Snake Oil"...as I have never believed in "Quik Fixes" with "Additives"...but nothing else ever worked. I went from 220 miles a tank to 300 after 2 tanks......OBD2 still says ALL GOOD with NO Check Engine light after 500 miles....
Just my story....my own experience with this product. Alot of guys here seem to know a lot so I was seeing what the Heck this did to give me such results????
Product: https://www.duralube.com/products/s...R8GRK7Z9LdEHGZXC6VYuI0CC2BUdqDCG2MpeiBHvDsciU
Thanks.
SRD
*Codes:
*P1409
*P0402
*P0455
*P1309
Thanks.
SRD
