Mine has a rubber cap there and there is nothing coming out. However, it is just a soft rubber dust cap, not meant to hold any pressure. I would expect that a leak at that point means "replace the whole control block."
Before doing that, clean the whole assembly real good with brake cleaner and rags. Then watch it over a week or two to see if there really is a leak.
Yeah, that should be the bleeder for the ABS block that appears to be leaking and yes, originally they had a rubber dust cap, but if it’s leaking, that missing dust cap isn’t the problem.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
