- Sep 4, 2017
- Age
- 47
- Lyman
- State - Country
- ME - USA
- Other
- 1987 Ford bronco ii 2wd
- Vehicle
- Ford Ranger
- Drive
- 2WD
- Manual
- Total Drop
- 3'' front 4''back
- Tire Size
- 245 35 18
So I recently installed high pressure pump on my current purchased bronco ii.I had everything reconnected,went to turn key to run position and got no fuel. Both pumps appear to be getting power.So I disconnected fuel line that goes to inlet of high pressure pump and turned key to run again.no fuel! Not sure if purging the fuel system is needed after replacing this pump? Also I disconnected fuel pump relay to see if pumps shut off and I noticed the low pressure intake pump appears to getting power still because I hear a click sound coming from tank. I thought disconnecting relay would shut down both pumps! Is this not the case? If not where does in tank power get its power from.I thought both pumps where connected together in some way.let me know.
