Instrumentation Panel Swap
RangerFella
OKAY...
I have a 1997 Ranger Supercab XLT 2.3L I4 5spd 2WD
My current panel has Fuel, Speed, Oil Pressure, Battery/voltage, and Temp...but no Tach.
I want a tach, I don't want to install some "do it yourself" crap in there because all those gauges look cheap to me and it's not stock, I want stock. Is it possible to get a panel that has a tach that's specifically for my truck? Surely not all the 2.3's have the same clusters, right?
Two more questions: 1. What would I have to sacrifice to have a tach...like what do I have now that I'm not going to have if I swap? Oil pressure? battery level? what? 2. How hard is it going to be to do this? Am I right in thinking that everything should just plug right in or am I going to have to modify a bunch of stuff to do this? Like could I do it in a few hours or is this a 'several day' ordeal? I guess I have to pull the entire dash out?
I had bought an aftermarket tach from AutoZone but...it said something about splicing the wiring harness for the PCM and my immediate reaction for that was "no way in hell" and I took it back the next day.
What I mean by "get a panel" is...could I go to a junkyard and get a panel from another 2.3 that has a tach in it and just plug it right in?
If you can find one from a 95-97 Ranger ,just remove the old plug in the new.If ya get one from a later year 98-on it'll work but you have to change pins for the CEL,and possibly the temp gauge will read high. I just swapped a 99 Ranger instrument panel into a 96 Ranger this week-end.Works fine except for above.Still gotta locate and repin the CEL.It's a pretty simple change.
I put a same year replacement in my 93 for the same reason. Everything works and now I have a tach. When I got the truck, I couldn't believe that a stick shift truck didn't have a tach, but found out it was an option that you had to pay more for.
Alright...well that answers the question about if I can find one that will fit my truck but...how hard is it to do this? Am I going to have to pull the whole dash out and everything or...? I mean like how long is it probably going to take? Several days? a week?
It just occurred to me...if I change the gauges out...isn't my truck going to have different mileage? For instance my truck only has 69k miles on it...if I get a cluster from a junkyard from another ranger...isn't the mileage going to be wrong? Or can I fix this somehow?
And that brings up another question: isn't this a really, really easy way to make your truck have low mileage when you go to sell it?? I mean...you could just take a panel that reads fewer miles and put it in there and no one would be the wiser. Not saying that's something I'd do...but...yeah there's something unsettling about this.
Also...the tach wires and everything are already there...correct? I don't have to wire anything, right? Like I can just plug the things back in and the tachometer will work?
It should just plug and play, but it should be a cluster from similar model years and the same engine size (clusters are usually marked to be used with a specific motor), using a 4.0L cluster with a 2.3 and your tach may read incorrectly.
There are a couple methods for adjusting mileage. All of them illegal. Actually, you're even supposed to report a gauge cluster swap.
Just put a cluster from a 99 Ranger 4.0 into my 96 2.3 and the tach is fine.The problems(minimal) are that the temp gauge reads high,probly a difference in resistance required at sensor. The CEL dosen't function but I'm sure it's a wire location problem,just have to change it in the connector.All else is fine.
I didn't say it wouldn't work, I said it may not read correctly. If you've ever looked at aftermarket tachs, many are V-8 specific or have a switch either inside or outside that adjusts for how many cylinders you have so that it can make the correction to read the proper rpms.:tease:
